1 - 7 of 7 Posts
its pretty hard without them,.. i tried using some skinny flat head screwdrivers... work beatifully the 1st time,. not so good the second time.. kinda bent some ****.. so i wouldnt recommend it without the pullers.
I used to do it a metal clotheshanger...
the hanger works pretty good ive done it that way
Like others stated, a set of small screw drivers or a metal coat hanger and maybe you'll get lucky. Or break down and buy the tool for $5 in the Wal-Mart car stereo section and maybe take it back when your done with it ;)
Whatever you try, the goal is to stick whatever in the holes and push them in the outward direction, this will pull the latch in and release the clips.
i got it out, i bent the tabs in the mid part of the radio then tok 2 fla heads to bend the platic away from the 2 clips the stop it from going forward
i work at a lincoln mercury dealer and i dont feel like paying 35 bucks for the little puller so i just use a coathanger its the same exact thing basically
1 - 7 of 7 Posts
