1 - 6 of 6 Posts
i am putting some subs in the trunk of my 04 mach 1 how do i lift up the back seat to put the wires under or what else should i do
take a flat head. run it under the seat, there are 2 push pin type deals and it should unlock it. Just be patient, they dont want to come out the first time. And i would run the power through the center console so you dont get whine from the rca. Plug the 1/0awg wont go under the trim, lol
the kick pane, and the door trim. I have huuuuuuge wiring. If you have 4awg you should be ok. Just make sure your rca's and the power are on opposite sides of the car or you will have alternator noise.
how do i get it under the carpet between the console and seat so it can't be seen at all
prybar or a flathead. haven't had a chance to get that far. Notch a groove in the rear of your center console so you dont pinch the wire. some water should free the glue up or heat.
1 - 6 of 6 Posts
