1 - 12 of 12 Posts
remove this?
want to ask before i end up breaking **** lol.
but it these a clip thats not clipped on n i hear noise into the cabin, n well this is something i can get fixed unlike my damn rear suspension (noise wise)
remove seatbelt from inside rear of car
then remove interior c pillar panel
you will then need to remove the screws holding in the exterior c pillar
then remove the upper door weather striping, then remove the metal c chanel that the weather striping was in
then you can remove the screws holding in the outer trim,
the outer trim is held to the c pillar with a screw and the c pillar needs to be removed or atleast loosened to get the screw out
  • Like
Reactions: 1_nice_03_gt
damn that was fast, thanks i shall get to it tomorrow :) reps to southfour
sorry froush gotta spread the love before rgiving u reps again
this is from when i installed my mach 1 c pillars
here is the pillar removed from the car, you dont need to remove the glass
i have circled in this pic where the pillar bolts to the side trim
that is underneath the side trim but you will need to be able to get your hand and a wrench behind the c pillar to remove the bolt
the weatherstipping hanging in the air in this pic is what needs to come down to get to the bolts holding the trim in along the edge of the roof
it just pulls out by hand
you can also see the weather stipping hanging here, dont need to remove it from the door jamb where it is rivited in
no im not talking about that part im talking about the front part of that above the driver/passenger window
i know, im just showng you what i happen to have pics of
the c pillar needs to come off first to get to the side trim you want to remove
damn really fudge
might aswell pick up some mach 1 pillers then
K1w1
I didn't think that was what the OP is referring to. I thought it was the bit that goes over the door.
damn really fudge
you might be able to get the bolt by just loosening the top few bolts holding the c pillar on, i had it completly removed because i was replacing it
its really a pain in the ass to get off
Discussion Starter · #12 ·
hmm ok i'll try that
1 - 12 of 12 Posts
