1 - 3 of 3 Posts
i removed the top bolts and bolts on the side of the block but its still being a pain in the arse i try banging on it but the crank is in the way .....do i have to remove the real main seal first?:mad:
bolts are off
After you removed the side bolts did you also back the other part out that the bolt goes through.
no....you talking about the washer looking things on the side of the bearing caps?
1 - 3 of 3 Posts
