1 - 2 of 2 Posts
ignition while cluster was unplugged to put up a window. Now I have the light flashing. Thanks in advance. :)Nel
If the light is flashing, the diagnostic monitor for the airbag has triggered a trouble code. What is it flashing? For example, if it flashes three times and pauses for one second then flashes again twice, that is a 32.
flash flash flash (pause) flash flash = 32
Or is it a rapid flashing with no pauses?
Here is the list of codes:
-- no airbag indicator - inoperative lamp circuit or no ignition voltage to the diagnostic monitor
-- continuous airbag indicator - diagnostic monitor disconnected or inoperative
12 - low battery voltage at pin 13
13 - airbag circuit or sensor circuits shorted to ground
21 - safing sensor not mounted to vehicle properly
22 - safing sensor output circuit shorted to battery voltage
23 - safing sensor input feed/return circuit open
24 - safing sensor output feed/return circuit open or low resistance in a primary crash sensor
32 - driver side airbag circuit high resistance or open
33 - pin 7 not grounded
34 - driver side airbag circuit low resistance or shorted
35 - pins 8 and 9 shorted together
41 - primary crash sensor circuit high resistance or open
44 - RH headlamp primary crash sensor not mounted to vehicle properly
45 - Center radiator primary crash sensor not mounted to vehicle properly
46 - LH headlamp primary crash sensor not mounted to vehicle properly
51 - diagnostic monitor internal fuse blown and short to ground no longer exists
52 - back-up power supply voltage boost fault
53 - internal diagnostic monitor fault
-- rapid continuous flashing of airbag indicator: all primary crash sensors disconnected
1 - 2 of 2 Posts
