1 - 2 of 2 Posts
What is it?
Hyper Ground System is a new generation tuning system designed to provide a direct, low-resistance ground path from engine components to the battery. It allows the entire electrical system to perform at greater efficiency, which can result in:
- increased hp
- increased torque
- improved fuel efficiency
- stabilized idle
- brighter lights
- quicker engine starts
- reduced emissions
- reduced audio noise
How does it work?
In any electrical system, electric current flows from the positive terminal to the electrical components, and back to the battery through the negative terminal. However, the way that the factory (stock) grounds are set-up, the electrons must travel through the steel and/or aluminum components in the car to complete the circuit, which creates much electrical resistance (steel/aluminum are not the best materials for electrical conductivity). This resistance disturbs the flow of electricity to a degree that electrical components such as ECU, lights, spark plugs. etc, cannot perform at maximum efficiency. In order to get the highest performance out of any automobile, it is necessary to achieve an efficient flow of electricity with the least resistance along its electrical circuit. By providing a direct ground path using highly conductive 99.99% pure copper, this electrical resistance is reduced greatly (as much as 10 times!), resulting in an ultra-low resistance ground path. In short, Hyper Ground System affects the electrical system similar to how a high performance intake and exhaust system affects the mechanical system, by scavenging power which would otherwise be lost due to system inefficiencies.
What makes it so special?
Sun Auto produces the Hyper Ground System to an exacting level of utmost quality. The cables are made to our proprietary design, constructed using thick-gauge 99.99% copper, with 1,477 strands per cable. Since the electrons only travel on the outside of the strands, many strands are necessary to maximize the electron flow. The cables utilize multi-layered shielding, which is specially blended to provide minimum electron leakage as well as to withstand engine room temperatures and protect against discoloration. Terminals are available with gold-plating, for better electrical conductivity and protection against corrosion. The Hyper Ground System also uses a patented “daisy-chain” method to connect directly from the cylinder head and other points under the hood to the battery, to provide an ultra-low resistance ground path. The kit comes in 3 universal sizes to fit any type of vehicle, and is effective for use in anything from bone-stock to fully modified vehicles. Aside from the universal kits (5 cables in different lengths), Sun Auto offers a lineup of car-specific kits, which are tailor made to fit a specific vehicle.
What will fit my car?
Hyper Ground System will fit virtually any vehicle:
Universal S-Type: for most 4 cylinder and V6 vehicles
Universal M-type: for most inline 6, V8 and larger vehicles
Universal L-type: for most cars with front engine/rear battery configuration
Optional wires in varying lengths are also available to supplement the universal kits and/or for custom applications.
Are these products legal?
Hyper Ground System was designed for use as OEM optional equipment. Generally speaking, any product that is authorized for use as original equipment by a car manufacturer is done so under the agreement that the parts are legal for use on public roads. Installing Hyper Ground System on your vehicle is not necessarily a modification to your vehicle, but rather an addition that supplements an existing system for increased efficiency. Hyper Ground System is not a replacement for your existing factory ground system; it is designed to be used in conjunction with your factory grounds to enhance electrical system efficiency through a direct, low-resistance ground connection. In any case, it is always best to check with your local laws and regulations to verify legality of any products you purchase for your vehicle.
- increased hp
- increased torque
- stabilized idle
- brighter lights
- reduced emissions
Got any dyno sheets to prove this? Did you know that the oem designers account for the electrical loss and put all the grounds in the locations that they did to minimize or eliminate ground loop issues?
1 - 2 of 2 Posts
