1 - 13 of 13 Posts
It's not easy being green!
Alright well about 2 weeks ago I saw a grease spot under my car, under the right rear tire leaking down my brakes on the inside . I drove up to my local mechanic and he told me it was axle grease and that I needed my seals and breaings replaced. He quoted around 300 bucks to fix it. Now I haven't been driving at all lately because I don't want it getting any worse and there's no major or even minor noises coming from my axle but I was wondering how difficult it would be for me and my dad to do this ourselves?? I mean if I could save that much money I would like to but I'm not sure. It seems fairly easy to do from what I have read online but wanted to get your guys input. What do you think?
I replaced the axle seal on my KW 900 it took me three hours so I couldn't imagine a car being all that difficult. I'll tell you it is messy I recommend jacking the side of the car your working on up. less axle oil will come out. You may get away without replacing the bearings. Good luck and post us a write up with some mad pics.
Just Cheesin'
Seal and bearings is a breeze on the cars.
You simply:
Jack up the ass, block the front, and take the park brake off.
Remove rear wheels
Remove calipers and pads
Remove caliper bracket and rotor
Open diff cover
Pull out both C-clips (Remove the 5/16 bolt hold the center pin in, and slide out the center pin. Push the axle in and rotate and they will just fall out)
Slide the axle out
Remove seal (there is a tool for this called... yup... a seal remover)
Remove the bearings (You need a slide hammer and an internal/external 3-jaw attachment)
Install new bearing (You can use a socket that will just barely slide in the axle tube. That or a bearing/race driver set)
Lightly grease the bearing
Install seal (Use what you used for the bearing)
-Slide axle back in(Make sure it slides into the diff)
-Reinstall C-clip ( - means repeat on other side before moving on)
Reinstall Pin
Reinstall diff cover with new gasket
Fill it with two bottles of diff fluid (75w90 oil, synth. or conv.)
Reinstall brakes and wheels
Enjoy.
  • Like
Reactions: ComTruise
Hmmm doesn't seem that bad. Should be able to do this ourselves
Just Cheesin'
I did it to my car with my dad. Only took about 2 hours. And this is when I had no idea what anything on the car did.
Thanks Red, reps :)
I'm also gonna get one of those Haynes manuals to help........was gonna get one anyway.
Just Cheesin'
It's a good thing to have. I used it a lot.
1 Wheel Peel
Good time to install some gears.. Rearend work isn't as tough as people play it out to be.
Just Cheesin'
+1
I rebuilt my [8.8] rear end with new bearing and seals, rebuilt the posi with carbon fiber clutches, and geared it myself.
It was a breeze.
The soul stealing Ginger
dial indicator is for measuring backlash on the gears im assuming? i cant image he would need it for replacing bearings and seals
1 Wheel Peel
I didn't say he did to replace the seal. For gear install he would
You also use it to measure axle endplay and ring gear runout
Just Cheesin'
Too much end play means a rattle while driving. Very annoying.
I think we are confusing him green..
1 - 13 of 13 Posts
