LOL
when i was stock, i bought my tuner and let Bama do the rest.
Shift point from 1 - 2 was 6000 RPM
ive done it 100 times. NEVER had a problem. Even though I am starting to wonder if it contributed to my cam bearins looking the way they did lol
Anyways, Stock my car shifted like 200 into redline in 1 to 2.
Now the other gears had lower changes, simply because they do go through the RPMS as fast. Hence they dont need to stay in high rpm like that for long.
Yes peak power is is about 5250, there is a point in pushing it further ... For both auto and stick. If you shift @ 5250, what RPM range will you be in the next gear ?? 4000 ?? Just a guess im not sure lol But anyways. Now your 1200 below peak power at the beginning of that gear. If you would have shifted at 6000, you'll be 500 away from peak power.
1250 rpm and can quite a bit of climbing to do when .1 seconds count.
So the point of shifting higher is so that when you do shift, your closer to the peak power of the next gear, there fore you dont have to build up to max power near as long. Just think if you could have that max power to the wheels from the time you start till you finish, instead of having to build up to it, and build up to it, and build up to it again...
Thats what it helps you do, stay closer to the max power in each gear.
Yes it sounds like ****, but if your at the strip and you are seriously trying to race, you might as well hand the Vtech guy if you shift @ 5000-5250 .... Losing alot of time that way.
Now, I know a guy w/o a stock motor that can shift to 6500. His name is ***-^
[email protected]*
