1 - 5 of 5 Posts
91 5.0 was going to go with gt40s but decided to do the trickflow topend kit. my current list of mods are with 3.73's,trick flow track heat intake,75mm tb and spacer bbk, fuel pressure regulator,bbk cai, cobra computer(X3Z),2 row radiator and blue hoses,hooker super comp long tubes coated, xpipe,spintech pro streets,have an A9L with a 76mm bbk maf should I put that on.
p.s what fuel pressure should I run to be safe?
with trickflow top end ~ 320 rwhp
any realistic 1/4 mile time with lowering springs upper lower control arms,subframe connectors, 373s same engine set up.
fuel pressure 39psi with vacuum line off fuel pressure regulator
i would say mid twelves with sticky tires and good driving
1 - 5 of 5 Posts
