I'll be upgrading the fuel system soon on my Mach to be able to run E85. Below is a list of my plan (only things left to buy are the fuel line, fittings, and filter) and a couple other things I'm now considering after talking with the shop and tuner.
03/04 cobra tank
03/04 cobra stock fuel hat
2 GT Supercar (Walbro F10000302) improved E85 pumps
KB 40amp BAP
Modified FPDM
-8 PTFE feed line
some kind of 10 micron stainless fuel filter
stock fuel rails
80lb injectors
The shop recommends getting some better upgraded parts now so that it is easier to convert to return style, and so I'm not paying for the same labor twice, once I build the motor in the future sometime.
They recommend:
Fore Returnless dual pump fuel hat (can be used in return style as it has a port for the return line)
-10 PTFE FEED LINE
I understand the point of doing the Fore hat now if I want to go return style in the future. Is there any benefit of using the Fore dual pump hat over the stock cobra hat in a returnless setup? Is a -10 feed line overkill on a returnless setup? Does a -10 support a lot more than a -8 and is there a duty cycle difference say on a 500rwhp unlocked auto car (~550rwhp stick equivalent).
03/04 cobra tank
KB 40amp BAP
Modified FPDM
-8 PTFE feed line
stock fuel rails
80lb injectors
They recommend:
-10 PTFE FEED LINE
