1 - 8 of 8 Posts
are the tunes that come from brenspeed locked so that u cant change stuff on'em?
i just had my cats cut out and although its not throwing a code i still want to turn the sensors off but i cant seem to figure out how to do it
only option i can change is two things with the Spark? current setting on those two options are 0-2000 and 0degrees
so either i'm missing how to go onto the next options or they're locked out?
using xcal2
thnx ahead of time!
i need to know how tho...cuz i'v obviously not doing it right....cant find the option for it
Drop Brenspeed an e-mail. I know on mine they had already turned the sensors off and I didn't have a off-road h pipe yet.
guess i'll try brenspeed then, thnx
booooost'd
I will throw a code. It took mine about a day before the code came up. You have to edit the tune before you load it. after you pick the tune you want it will ask you if you want to make any adjustments. just scroll threw the options untill you find the ones you are looking for.
1 - 8 of 8 Posts
