haha at least you gota good idea of where your abilities are now so next time you do betterI don't have the answer to your queston but good luck. I killed my car and that was on street tires. It was embarrassing
there is a good video clip of ryan's car launching in my thread
i wont just spin if i do this? i am on gay 3.08 gears for now18psi 4000 and up rpms and dump it. Feathering the clutch is only gonna give you a crappy 60'
With those gears it is still optimal to launch as hard as possible. If your tire size is 275 on a drag radial, youll be fine. I suggest that you try everyones advise, but I am willing to bet 4K dumps work best.i wont just spin if i do this? i am on gay 3.08 gears for now
g ****... +1but I am willing to bet 4K dumps work best.
this is what i was talking about earlier.....didn't realize they were nitto's until just a little but ago, im used to everyone going with the et streets on heredropping the pressure on drag radials will only help a little and you'll be giving up stability on the top end. I wouldn't go much lower than 20PSI. With a good set of tires like ET streets you can drop the pressure to 10-15 PSI and it will hook hard.
