1 - 8 of 8 Posts
i cant seem to get hold of this stupid bolt on the bottom of the iac so i can clean it. i dont think its been cleaned since i bought it 10k miles ago. probably more than that. i have a 01 sixer. its such a tiny space to work around any ideas?
I'm doing it wrong
Only thing I can come up with is pulling the upper intake off and see what you can work with. I snapped the head off one of my iac bolts. But it's different than your situation. I just pulled off one bolt and twisted the iac around until it came off.
well i can get one bolt off. i guess ill try the twisting the whole iac thing if i have no luck. i just hope it doesnt ruin the gasket. if it does where can i grab a new one?
Not A Regular Member
I snapped the head off of one of my IAC bolts as well :sorry
Get a pair of vise grips. Clamp them ****ing tight. Turn them as much as you can. Unclamp. Repeat. If you've got a quality pair of vise grips then you can probably get ahold of the bolt and get it to turn. Also you can pick up a new bolt at pretty much any hardware store. Just take in the bolt that doesn't have a stripped head and find one that matches. It'll cost maybe a dollar.
I actually had to use a pair of vise grips to remove my snapped IAC bolt because there was absolutely nothing to put a socket/wrench on.
alright ill try that then. thanks again mcqueen!
Livin' the Good Life
If you can loosen the bolt by turning the IAC, it should be hard at all to get it off. Just patience and mcqueen.lol :)
1 - 8 of 8 Posts
