1 - 11 of 11 Posts
Cones = Yummy!
So I've got Steeda Springs (installed when I got it), I've since upgraded the shocks and struts with Eibach Pro Damper Kit... it's better, but still hard on the bumps..
I know lowered/performace stance vechilces are harder (I don't expect it to ride like a Lincoln) but I'm wondering what else I can do to soften up the travel a bit...
I've got Sway Bars coming (but I know that won't impact this much), so wondering if maybe Eibach Springs (or others) are worth the trouble of a swap, or if there is another component commonly swapped to create better ride comfort.
Low & Slow
I don't think swapping the springs is gonna do much at all.
If you already did shocks & struts, I think the only other option for you is a coilover setup...
Cones = Yummy!
That's what I figured, but I don't think I can justify $1200 for coil overs... it's not THAT bad.. that's $1200 in the wrong direction from my SC..:)
Cones = Yummy!
thanks.. yeah I'm going with 18"s soon but going to increase overall size to fill the well and keep the sidewall depth..
It's great at high speeds, it's the slower big bumps that suck.. Ehh.. just thought I'd ask, this is my first car I've modded, done trucks in the past so I'm used to it..
thanks again!!
Dont go 18". I have them, love them actualy but if you want a 315 tire they are hard to find and expensive when you do. I am droping to 17x10.5 in the rear/17x9 up front
BYAHHHH!
18's are pricey for tires. You can run a 305 tire on them tough. not a big difference then 315s....
1 - 11 of 11 Posts
