1 - 4 of 4 Posts
Booger Bear
How can I tell what transmission I have?
5 speed.
That's all I know..
If it's an '02, then it's a T-3650 if it's the stock transmission.
The 3650 also has the drain plug on the bottom of the trans, where the T45's drainplug is on the side.
MM Gaming Guru
^^ what he said. Should be the T-3650. Can always verify for the sake of it on the little tag on the driver's side door jam. There's a spot in the bottom right labeled "TR" and beneath it some letters/numbers. You should see a "K" as the first character, identifying it as the T-3650 from the factory. THe rest of the digits pertain to springs and other junk.
1 - 4 of 4 Posts
