1 - 11 of 11 Posts
can you give me some rwhp estimates and/or track times for my new motor i am currently putting together hopefully running in about 2 weeks
stock 302 bottom end fresh rebuild with stock pistons
GT40 iron heads gasket matched
e303 cam
1.7rr
k&n
C&L 76mm maf w/inlet pipe
bbk 70mm tb
trickflow street heat upper/lower
bbk long tube headers
bbk off road x
30#injectors
bbk adjustable fuel regulator
also if your going to give estimated track times
it is a 5 speed car
3.73, if i do run at the dragstrip it will have
m/t drag radials
I am guessing and hoping for around 275 rwhp 310 rwtq and about 12.70-12.90 What do you guys think??????
i think your estimates will be close.....depends on how well you can drive also
Who Care's ... Boost It!
Your torque est is waaay off dude, you're gonna have way more ft lb torque than just 310. The stock torque is 300 and you have gt40 heads and all the other fantastic mods. You're gonna kick about 350-360ft lb torque. Don't dump the clutch at the light, you could be running 12.5's 11,8's on the 1/4.
i cant see an 11.anything from that car
e303 cam
1.7rr
k&n
bbk 70mm tb
bbk off road x
30#injectors
it is a 5 speed car
m/t drag radials
Sounds pretty close. It will run high 12s easily if you can drive it.
Note the part where he said RWTQ....
1 - 11 of 11 Posts
