1 - 4 of 4 Posts
3rd grinds with any kind of brisk shift into it,... i gotta be easy,.. this would be a syncro problem? or could something like this be fixed with a tranny fluid change... ... Fluid hasnt been changed in quite some probably
Is your fluid level low? If so, that might be the problem. But if the fluid level is normal, probably will not make a difference by changing it. Either a synchro or shift fork. Get it taken car of before the gear gets messed up too.
how to check fluid? and both fork and syncros hard to change?
You have to remove the trans and dissasemble for both. Check the fluid by taking the fill plug out on the middle of the passenger side of the trans and stick your finger in there. If you feel the fluid, it is full. If not, it needs fluid. You can either squirt some in the fill plug or put it in the shifter opening.
1 - 4 of 4 Posts
