1 - 2 of 2 Posts
it SHOULD, the inside is whats bigger, i think on the 75mm the outside may be a little bit bigger though, if you need to you can always soak the coupler in really hot water then use a little wd40 on the outside of the tb to slide the coupler on while is hot and soft. it will stretch out and then stay that way.
1 - 2 of 2 Posts
