So as you may know i just finished the pi swap and my car is running lean. apparently it was running lean before the swap. I had some codes read today that showed the following:
P1131-Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank1
P1132-Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank1
P1151-Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank2
and one random o2 code for the downstream. but i have eliminators and the downstream has no effect on the air fuel ratio.
My symptoms are:
after the car gets warm the idle surges. 200rpm-600rpm
when driving at a constant speed and press the clutch in, as the rpms fall it dies. and my air fuel ratio gauge is reading lean constantly.
I replaced oxygen sensor bank 1 upstream today and it had no effect on the issue. I will try to replace bank 2 as well tomorrow and test the injectors. I have no clue what is going on. any ideas?
My symptoms are:
