1 - 3 of 3 Posts
So i recently bought a spec stage 3 clutch and put it in in the 5th. Its almost fully broken in but now it doesnt catch until its almost all the way out. So i figured it just needs to be adjusted. Soooo. How do i tighten it?
Thanks for any help.
did you install a after market clutch quadrant, fire wall ajuster? if so the proper setting is to pull on the clutch cable at the fender wall ajuster and turn the ajuster so there is a 1/8th gap. other than that the clutch will grab where it grabs and the ajustment for that is at the pivot ball. or you can use the maximum motor sports pedal ajuster.
mm clutch pedal ajuster
Clutch Pedal Height Adjuster, 1994-04 [MMCL-7] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Honestly im not even sure if i have an adjuster. Would it be behind the clutch pedal? And it wouldnt cause any problems grabing that late in the release would it?
1 - 3 of 3 Posts
