M'kay. The following is the list I've been putting together, in order of what I'll be purchasing for the most part, of what I plan to do to Philis based on what I've seen others' recommendations and what they did or didn't like. Feel free to critique and advise cheaper and/or better options!
02/05/2013 Update: Since I ended up sacking the wheels first plan and got the exhaust done, I've finally ordered the wheels and tires! Was originally going with the NT05 315/35/20s in the rear, but since Online Tires have such a killer deal on the Eagle F1 G3-D3 305/35/20s at $150 a pop (retails $615 or so), and the NT05s were at $300 or so per, I decided to try these out. I'll be sure to post pics and such when they're installed! They may not go on for a month or two, depending on the weather in this terrible state...
**First** (purchased, installed)
Borla Stingers Exhaust: Borla Stinger S-Type Mustang Axle-Back Exhaust (05-09 GT) 11750 - Free Shipping!
**Second** (purchased, installed)
Mac LTs + Prochamber:
2005-2009 Mustang GT 4.6L MAC Long Tube Headers & ProChamber Kit
**Third** (purchased, waiting for arrival)
Wheels:
Black Faleen 7-spoke 20x9 x2:
Black S197 Mustang Saleen Style Wheel 20x9 (05-13 All) - Free Shipping!
Black Faleen 7-spoke 20x10 x2:
Black S197 Mustang Saleen Style Wheel 20x10 (05-13 All) - Free Shipping!
Black 6 Spline Lug Nuts:
Black Mustang Six Spline Lug Nuts - Free Shipping at - Free Shipping!
Tires:
Goodyear Eagle F1 GS-D3 305/35/20 x2:
EAGLE F1 GS-D3 - OnlineTires.com
Nitto NT555s 255/35/20 x2:
NT555 - OnlineTires.com
**Fourth**
Power Slot slotted rotors, front and back: Mustang Products: StopTech big brake kits, tires
**Fifth**
MGW Short Throw Shifter: Mustang 2005-2009 Short Throw Shifter
MGW Classic Shift Ball Assembly: Mustang 2005-2009 Short Throw Shifter
**Sixth** (probably will buy one at a time, but will wait to install when I have the full suspension kit so I don't screw up my alignment, etc)
FRPP K-Springs: Ford Racing Mustang K-Springs (05-13 GT) M-5300-K - Free Shipping!
Koni STR.T Shocks and Struts:
2005-09 Mustang Koni STR.T Rear Struts - Pair of 2
J&M Caster Camber Plates:
J&M Mustang 4-Bolt Camber Plates (05-10) 24220 - Free Shipping!
BMR On-car Adjustable DOM Panhard Bar w/ Poly/Rod Ends:
2005 - 2012 Mustang GT | Panhard Rods | PHR013 - Panhard Rod, DOM, On-car Adj, Poly Bushing/Rod End Combo | BMR Suspension - The Leader in High Performance Suspension & Chassis
**Seventh** (may opt for LCAs before these, depending on how much issue I experience w/ wheel hop at this point)
Hot Rod Cams: 2005-10 Mustang GT Ford Racing Hot Rod Cams, M-6550-3V at LRS - Free Shipping!
**Eight**
BMR LCAs w/ Poly/Spherical Ends:
2005 - 2012 Mustang GT | Lower Control Arms | TCA022 - Lower Control Arms, Boxed, DOM, Non-adj, Polyurethane & Spherical Bearing Combo | BMR Suspension - The Leader in High Performance Suspension & Chassis
**Ninth**
TruFiber GT-S Ram Air Hood: 2005-2009 Mustang Tru Fiber GT-S Ram Air Hood
**Tenth**
BMR K-member:
2005 - 2012 Mustang GT | K-Members | KM011 - K-member, 1/2" Lowered Motor Mounts, Standard Rack Mounts | BMR Suspension - The Leader in High Performance Suspension & Chassis
**Eleventh**
BMR Adjustable UCA w/ Poly Bushings:
2005 - 2012 Mustang GT | Upper Control Arms | UTCA019 - Upper Control Arms, DOM, On-car Adjustable, Polyurethane Bushings | BMR Suspension - The Leader in High Performance Suspension & Chassis
BMR UCA Mount:
2005 - 2012 Mustang GT | Upper Control Arms | UCM001 - Upper Control Arm Mount | BMR Suspension - The Leader in High Performance Suspension & Chassis
**Twelth**
SLP line locks: SLP Mustang Line Lock Kit (2007-2009 GT & 2007-2008 GT500) - Installation Instruction M25002 - Free Shipping!
**Thirteenth**
McLeod RXT Street Twin Disk Clutch Kit:
McLeod Racing - RST Twin Disc
**Fourteenth**
Axle Exchange aluminum one piece driveshaft:
Mustang Aluminum One Piece Driveshaft (05-10 GT) MAAT412 - Free Shipping!
**Fifteenth**
Roush Pre-painted Body Kit: 2005-2009 Mustang Roush "Racer" Body Kit - Painted
**Sixteenth**
Eaton Detroit Truetrac Differentials:
Detroit Locker 913A561 - Eaton Detroit Truetrac Differentials - Overview - SummitRacing.com
**Last Pain in the Ass, Kick to the Nuts Part**
Autolite HT0 Spark Plugs: Auto Lite Spark Plugs HTO
Roush TVS R2300 Supercharger Kit:
VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing: ROUSH 2.3L TVS Supercharger kit for 05-10 Mustang GT (6-rib)
As if I wasn't bored enough at work, now I'm starting to think ahead for when my engine is so old and worn it blows up, and what I want to replace it with. I have a pretty confident grasp on the stuff I'm getting up above...but this, it's like I'm back in the 2007 days when I first came here, completely clueless. :dunce: Originally, I was thinking a 5.4, but I didn't know if the SC would port from the old 4.6(if I even get to the SC stage before it dies) to the 5.4, so I set my aim at a 4.6 replacement. This section is very new, and any and all tips / advice are very welcome.
**Post Engine-Fail-From-Old-Age Solution**
Ford Racing 4.6L 3V Aluminator Short Block for Supercharged Applications: Ford Racing 4.6L 3V Aluminator Short Block for Supercharged Applications M-6009-A463SC - Free Shipping!
Needed: 8-bolt flywheel, unknown others
5/07/2012 Update: Originally, I had my heart set on doing a Barricade conversion. I may be veering away from the Barricade idea, or at least if I decide to try and pull it off it won't be until after most everything else. At first I was having doubts thinking about all the time that would be wasted on being pulled over by police officers thinking I'm impersonating them, but after voicing my concern to my friend,(more than once) he specifically talked to some of his law enforcement friends, and they said it should not be an issue here with what I had planned. I'm fairly confident the "impersonation" concern doesn't really hold anymore, but I also really don't want to wait till I have enough for the body kit and center exhaust to complete my exhaust, 'cause that ****'s expensive. At the moment, I've subbed out the Saleen kit with a prepainted(win!) Roush body kit. I'll give it some more serious thought when I get to that stage in construction.
Discuss!
(Old) Edit: I just noticed there's a new Projects section, lol...I'll ask to get this moved when I swap the wheels and post pics, I guess?
Wheels:
Tires:
**Fourth**
**Fifth**
**Eight**
**Ninth**
**Tenth**
BMR K-member:
**Eleventh**
BMR UCA Mount:
**Twelth**
**Thirteenth**
**Fourteenth**
**Fifteenth**
**Sixteenth**
Discuss!
