1 - 4 of 4 Posts
Cams if so what stage?
Nitrous if so what's a safe shot?
Its tuned already, and Turbo or S/C is in the works later dont have the $ money right now I sold the unit I had:sorry Because i did not have the full kit it came off a wrecked stang!
W/O gears I ran 13.48.
Now I have gears in and I'm wanting low low 12's high 11's!
mm's nitrous mod
depends on how much you want to spend. you will need a different tune for a power adder. i went 13.22 the last time i ran n/a. i have added and changed a few things since then, one of them being 4.10's. i know the car will get 12.8-9, just never went back to run n/a.
dmac where did u get your tune? do you have an SCT?
The car got tuned by the mechanic who had it before I picked it up in Xenia Ohio he turned off the TCS and bolted up the full exhaust system! I need to retune it since I have much more bolt on's. I should be able to hit lower mid 12's with a cam and low 12's with the N20. With both high 11's! With a new tune n/a 13.2's easy!
1 - 4 of 4 Posts
