1 - 2 of 2 Posts
Keep Moving Forward
So, I regularly autocross my daily Mustang. I decided it wouldn't be a bad idea to get front and rear stainless steel brake lines.
When we install them, we're gonna drain the entire system of its brake fluid to put all new in; as of now I have ordered a 12oz bottle of Wilwood high-temp brake fluid.
Will this be enough to fill the lines, abs, and all the way up to the filler under the hood?
Or should I have bought atleast 2 bottles? Maybe more?
i would say may need 3 by the time your done and if you are draining it all
but all you really need too just keep bleeding it till you get fresh fluid and then a little bit extra
1 bottle is just bleeding it through
2-3 if draining completely
1 - 2 of 2 Posts
