1 - 6 of 6 Posts
Boost gets you laid
well i think its about time for me to replace my clutch.. slips bad going into 3rd gear when i get on it and it chatters like no other from a stop. also my throwout bearing is loud as hell and extremely annoying..
so a few questions. is the spec stage 1 kit worth getting? thats what i'm looking at. i have no plans of forced induction for this car and it wont need a higher rated clutch.
also, i know i need to get my flywheel resurfaced but will getting a new one be a better idea.
lastly, what else besides the kit do i need? do i need a new cable or anything? thanks guys
a spec stage 1 should be fine if you dont have any big plans for the car,but most people on here would recommend a centerforce clutch. its a good idea to get your flywheel resurfaced to prolong the life of both of the clutch and flywheel, cheaper to do that then get a new one while you have your transmission out.
the cable will be a bit loose at the top end of the clutch pedal but nothing major. if anything a firewall cable adj will fix that
Boost gets you laid
are there any differences on the pressure it takes to push the clutch down? the stock clutch is pretty damn stiff..
it should be a bit easier. depending what you get. usually though i think racing clutches are harder to push so a stage one will be easier than a stage 3 but i doubt it'll be much different from stock.
Boost gets you laid
hmm ok cool, i'll look into centerforces and see what i come up with. i'm gonna be doing everything besides resurfacing myself so thats why i was asking about a cable and stuff
1 - 6 of 6 Posts
