In 1991, Ford Motor Company quietly slipped a new engine into the Lincoln Town Car to replace the 5.0, and no one blinked an eye. The Mustang GT and 5.0 LX were still powered by the trusty 302, and Ford fans figured it would stay that way forever. However, unbeknownst to Mustang owners, when the boys in Dearborn introduced that new engine, they might as well have announced that there's a new engine in town, it's name is Modular and we're going to stuff it in virtually everything with a blue oval. Amazingly, it's 12 years later, the 5.0 is long gone, and we've come to accept the Modular family of engines in our favorite Fords. It took some time to recognize these "cammers" as true performance engines, but the Modular V-8 has become a real winner, with the latest iterations making close to 400 hp in factory trim.
As we know, the road to the top of the performance hill was not paved with gold, but Modular engines have proven to perform both in Mustangs and in trucks. Unfortunately, those first 4.6 Modular engines ranked low on the performance chart and enthusiasts got a bad taste of this technology. First impressions mean a lot, and, quite honestly, the 215 and 225hp '96-98 Mustang GTs were not Modrific. In fact, most Stang Bangers and journalist-types considered them pathetic. Fortunately, Ford recognized the problem and substantially increased power for 1999.
If there's a downer to the Modular craze, it's that few aftermarket hard parts, such as heads, cams and intakes exist to boost performance, even though the Modular family of engines has been around for a decade. On the other hand, Ford owners looking for extra power can toss on a power adder and find well-over 100 extra ponies. Or, you can find the best factory parts and work them to perfection.
But how do you know which parts to mix and match? What parts will fit, which ones won't? There are many Modular questions so keep reading because in this first part, of a two-part article, we'll find out exactly which parts can be interchanged to make your Mod motor the best it can be. This month, we'll tackle the 4.6 SOHC engine; in the next issue, all your four-valve 4.6 queries will be answered.
A Mod Is Born
Most late-model Ford aficionados mark 1996 as a pivotal year in Mustang evolution because it marked the first time the Modular V-8 was used in a performance application. Some may argue that the '94-95 5.0 GTs were underpowered, but the SN-95 models were superior in ride quality, comfort and handling when compared to earlier Fox Mustangs, and with some simple aftermarket power parts, any SN95 could run with the pack. Then came 1996, and Ford fans watched the beloved 5.0 small-block disappear forever. The replacement displaced a mere 4.6L (or 281 ci). Few considered the "Modular" engine to be a performance V-8, despite the fact that Ford boasted about its many improved traits.
As we mentioned in the opening sentence, the first Mod engine was used in 1991, when a 4.6 SOHC was placed under the hood of the Lincoln Town Car (even though it was designed for front-drive, east-west applications). Shortly thereafter the 4.6 engine was used in the Crown Victoria, Grand Marquis, Thunderbird, and Cougar. In 1993, Ford released the all-aluminum DOHC 4.6 in the Lincoln Mark VIII, which became the predecessor to the Cobra V-8.
The roots of the Modular movement can be traced back to the late-'80s, to a time when Ford was looking for improved engines for its cars and trucks. While the last pushrod V-8 engines of the mid-'90s provided power and reliability, Ford was looking for a way to improve the overall performance of its engine lineup. This meant smoother-running engines with less noise, vibration, and harshness (NVH), better sealing, lower internal friction, along with increased fuel economy, increased longevity, less maintenance and all without sacrificing power. And let's not forget lower emissions. In addition, Ford engineers wanted an engine family that could share machining procedures and tooling as this would reduce costs.
Marketing also played a larger role in the demise of the 5.0 than you would think. Overhead cam technology was perceived to be more high-tech than pushrods, therefore more marketable. With this in mind, Ford started from scratch with a completely new engine design. The idea was that the basic dimensions could be used to build many different engines and power many different vehicles. Thus, the Modular engine was born.
For starters, Modular blocks are cast from iron (or aluminum in the case of the 1993-01 DOHC engines), and they all feature deep skirting with cross-bolted main caps and lots of webbing. Engine accessories are bolted directly to the engine, which makes for smoother overall operation. All cylinder heads are aluminum and have extra-long head bolts that extend below the cylinder bores into the main cap webs to improve cylinder sealing. Naturally, there are no pushrods, but there are hydraulic roller cam followers that are quiet and require no maintenance.
If there is a downside, it is the lack of displacement. Because of its FWD roots, the tight bore spacing severely limits the size of the piston that can be used in a stock block. Intake manifolds are mounted flat so gaskets aren't squeezed out, reducing the chance of a blown gasket.
Taking Shape
Though most folks were opposed to Modular performance at first, we now find lots of people building Modular-powered vehicles. Engine shops are preparing these engines, and customers want the most performance for the lowest price. So now let's take a look at some of the important parts and see what fits.
Modular engines slated for passenger-car use are assembled at the Romeo Engine plant, while the Windsor Engine plant builds the truck engines though some crossover does exist. There are five basic variations of the Modular engine: the SOHC 4.6, DOHC 4.6, SOHC 5.4, DOHC 5.4 (all V-8s) and the 6.8L V-10. All 4.6 engines have a 3.552-inch cylinder bore and 3.543-inch crankshaft stroke, making the engines essentially "square." And while the bore is on the small side, the 4.6 has a favorable rod length-to-stroke ratio. Rather than increasing the bore size, the 5.4 Triton engines gain the extra displacement from a longer 4.16-inch stroke, and the V-10 is essentially a 5.4 with two additional cylinders.
Since 1991, Ford has released many versions of the 4.6L V-8. This means there are different blocks, different cylinder heads, along with some different cams and intakes, too. There are also plenty of interchangeable parts, namely cylinder heads, cranks, and timing assemblies.
"We've been doing a lot with Modular engines lately," says Dan Millen of Livernois Motorsports. "All the [4.6 SOHC] parts fit from year to year, but you can run into a port alignment problem with the 1996-98 parts and the 1999-up parts. That's because Ford changed the port shape from round to rectangular in 1999. We've also found other little things like the PI [Power Improved] '99-up heads look identical to the Lightning heads, but the car heads have nine valve cover bolts and the truck heads have 12. You can use either heads on either engine, as long as you use the right valve covers." Most Modular fans are aware of the difference between the 1996-98 engines and the 1999-up engines. The first Modular engines (1991-98) featured rounded or teardrop-shaped intake ports, and they suffer from intake valve shrouding, and a larger combustion chamber. To remedy the power problem Ford Racing Performance Parts designed a "better" two-valve head with larger ports, reduced intake valve shrouding and a closed combustion chamber. Ironically, in 1999, Ford introduced "Power Improved" (PI) cylinder heads that closely resembled the Ford Racing heads but with rectangular ports and smaller intake valves. The PI heads with matching intake, increased horsepower on the 1999 Mustang GT engine to 260 from its prior rating of 225 in 1998. Any of these heads can be bolted to any 2V or 4V block, as long as the proper intake manifold is used. Keep in mind that putting 1999-up heads on a 1998-earlier engine will increase compression significantly--not a bad thing, but it's something to consider if you're using a power adder.
Millen provided us with cylinder head flow data that shows the improvement in the PI heads is mainly in low- and mid-lift flow, between .100 inch and .450 inch, but the 1996 heads actually out-flow the PI heads (see chart) at .500 and .550 inch.
When building a Mod motor you will need an engine block. We've found about 10 different cast numbers for blocks (from 1991-present), some are better than others. The Romeo plant built the first block, which was the F1AE, and it was used through early 1992. It was replaced by the F2VE casting at the same time Ford released the AODE transmission in RWD cars. This block was superseded by the F4VE, which is identical to the F2VE. All three blocks are virtually the same and have hollow dowels to align the transmission.
The next block in the long lineup is the Romeo-built F65E, but Ford also cast the F6VE and the F7VE. All three blocks are visually and dimensionally the same, have cross-bolts on all five main caps, and were used from 1996-98. There is a threaded hole in the cylinder valley for a knock sensor. These blocks are preferred over earlier blocks and will work in all RWD cars. The Romeo plant also built engines with a F7AE and XW7E casting number. They were primarily used in trucks from 1997-99 but can be used in passenger cars.
Production of the Windsor blocks began in 1996 with the F65E-BB and the F75E. Windsor blocks have cross-bolts on all five main caps and the bolt pattern on the front of the blocks is the same as earlier Romeo blocks. However, some of the holes may be 10 mm instead of 8 mm. This is important if you are purchasing a blower because the compressor bracket attaches to the front cover.
We also spoke with Ralph Pici of Power Heads Performance Inc. who stated, "Any of the two-valve blocks will interchange, but you want to stick with 1996-up blocks because they are the ones using cross-bolts on all the mains. There are differences between the blocks built at Romeo and the ones that come from the Windsor plant. The Romeo blocks have jackscrews that pre-load the main caps and the Windsor blocks use dowels. Both are OK for rebuilding. We've sonic tested a lot of blocks and usually find a wall thickness of .200 inch. The problem is they don't make [head] gaskets larger than .020-inch over so you're limited on how big you can bore the blocks."
We've found that the Modular engine can be built to take the heat of competition or for serious street use. There are dozens of parts but most will interchange. Our best recommendation is to keep as many of the original parts together and document them as you go. The major differences lie in the front covers (8mm or 10mm bolts), the main caps (jackscrews or dowels), and crankshafts. Otherwise it seems all parts can be swapped.
A Mod Is Born
Taking Shape
