I think i have a bad injector, when im driving the car at a steady speed its fine but when i give it a little throttle it seems to sputter, but when i have it in neutral it revs fine any suggestion? what else do you need to know?
Clean the MAF sensor.
Check the injector harnesses and make sure they're firmly attached to the injectors.
Check plugs, plug wires, dizzy cap, and rotor for wear. Replace as necessary.
Easy way to tell if its an injector start the car up and pull the plug on your injectors one at a time and you should notice the car stumble a little each time....if you pull one and dont notice anything and you do on the others then chances are you have a bad injector....
The injector failure rate is very low. Dropping out 1 cylinder is only 13% of the total. I'd suspect the fuel pump, maf, or tune WAY before a bad injector. With today's gas, injectors with 50-100K mi on them never look gummed up.
So i just took my car to be scanned and pulled a 136 which said 02 sensor heater so i took mine and exchanged them cause they still warranty but still does the same thing. Is there somthing else i should look at with the 136 code. Its getting annoying now and patience is wearing thin so any would help.
if you don't mind me asking, how much was it to replace your injectors? i'm running into the same problem, i don't have the time nor the know how to check out the injectors. i bought some used 24# injectors off of a 93 cobra (at least thats what the guy told me) and the C&L 73 or 74mm MAF calibrated for 24# injectors. and i'm wondering how much would it be to install all that. maybe i could get that damn sputtering problem fixed. i have an adjustable fuel regulator but no fuel pressure gauge. i should get one.lol. any ideas on which pressure gauge would be good on our cars? i don't know much about them. thanks!
1 - 20 of 20 Posts
