:bs:chillpill:gives:asshole:dunno
i have been down that road. not gonna do much better than a high 11 with a n/a 4.6 and its gonna cost you twice as much as it would to be that fast with a power adder.&475 fot the pulley, $450 for the Mezeire electric water pump, so you're looking at $1000 for about 20 or so HP.
Just spend the $450 on the Mezeire electric water pump, they say that will give you 15 HP.
Not everyone wants to throw a bottle or a supercharger on their car. It's more challenging to see what kind of horsepower you can get with just an N/A motor.
That pulley is to overdrive the supercharger and create more boost, def more than 20 hp there.Not everyone wants to throw a bottle or a supercharger on their car. It's more challenging to see what kind of horsepower you can get with just an N/A motor.
Are you gettin a 6 or 8 rib? Believe you can run a 8 rib pulley with a 6 rib belt, that way your setup for the upgrade later. Thats what Id doUmmm... who the hell would buy a new one? You get them used for alot less. The reason for them is to eliminate having to downsize your blower pulley therefore potentially creating slip. Naw dont think i wanna run nitrous through it with the blower. Im sure some do it, im just not going to.
$475 bucks!!!!!! you can buy a whole nitrous kit to make up for the amount of power you would gain from that pulley, and you could adjust the power you make. and it will create more torque. lol... i didnt know those things were so expensive
Don’t confuse overdrive pulleys with underdrive pulleys. An overdrive pulley is for supercharged cars. Supercharged cars are not N/A. There are two ways to spin a supercharger faster creating more boost: a smaller supercharger pulley or an overdrive crank pulley. The problem with very small supercharger pulleys is that you end up with belt slippage. Overdrive pulleys are usually only added after the smallest supercharger has already been installed. With the other supporting mods that it takes to get to high 500 to low 600 rwhp it will definitely generate more horsepower than a $400 nitrous kit.i have been down that road. not gonna do much better than a high 11 with a n/a 4.6 and its gonna cost you twice as much as it would to be that fast with a power adder.
