I've replaced the Panhard, LCA's and UCA and I have a maddening creaking noise coming from the UCA mount on the body. It's a creak, not a squeak. The LCA's are poly bushed so I expected some squeaks and, yes they are present.
This is completely different. I've pulled off the UCA mount again to look for any cracking in the areas on the body the mount bolts to and their good. It almost sounds like it's loose but I have gone over the mounting bolts over three times.
Has anyone out there had this issue when replacing their UCA?
Just a detail on that...it's not a poly bushing. It has a spherical rod end, is adjustable and uses the factory bushing in the rear end housing. Also to add the mount is also factory.
Any help would be great!!
