1 - 10 of 10 Posts
I'm gonna buy one soon, just wondering if there was a somewhat easy spot to install the sending unit at? I had one on my '95 and put the sending unit in the pan but I dont want to have to drop my pan again to put this in unless i have to. you guys got any tricks?
The best option really is to tap the pan or weld a bung with the appropriate sized threads onto the pan.
My personal opinion, take the money you would have spent on a trans temp gauge and everything for the install and use it to buy a deep sump aluminum pan and a trans cooler.
I already have a good size trans cooler running in line with the stock one. I guess i'm just a little paranoid about the temp lol.
A deep sump aluminum pan is going to drop the temps a bit more too by adding fluid volume and better heat dissipation. If you are paranoid about the temp, then doing things to make your trans run cooler is the name of the game. AM sells a trans pan for like $110 with our discount.
has anyone tried hooking the sender into the pressure test fitting? not sure if that'd work or not. I may just buy the deep pan then tap that for the sending unit so i'd be totally set.
You can run the sending unit into one of the fittings in the side of the case, but I'd rather have a temp reading based off the fluid in the pan. Btw, the PCM monitors trans temp as well.
nothing to worry about with temps in these trannys, once in o/d with the converter locked they don't get hot.
I agree with Will, spend the money on a pan.
BYAHHHH!
who makes a good pan?
BYAHHHH!
thanks sir
1 - 10 of 10 Posts
