1 - 11 of 11 Posts
how do i install an air fuel ratio guage and what parts will i need and or tools. any links with pics would be great
no its an autometer guage i know i should get a wideband thats later to come.
N/A 4v Guru
Do you have a mounting pod? Its the autometer electric AFR gauge right? If you don't have a mounting pod you can get the one that goes on the steering coulumn or the one that replaces the plastic around the gauge cluster, it has mounting pods for 2 gauges.
N/A 4v Guru
OOO. I got ya. I can't remember which wires he used but I will give sweet2k a call here in a few and ask him. we did his one night awhile back. Maybe someone will tell you quicker but if not I will let you know in just a little bit. Let me run over to his house.
you can just tap into the signal wire coming from one of your front o2 sensors. a good haynes manual will point you to what wire is the signal wire. thats where I tapped into.
N/A 4v Guru
There are dedicated accessory wires under the dash of the mustangs just for that.
1 - 11 of 11 Posts
