1 - 15 of 15 Posts
LORD ZERO VENOM SUPREMACY
Hey guys my first head install. I removed the head and I'm re installing a different head. Stock 2.3l from another mustang. I'm just wondering what needs to be done for the head/cam to match the block/piston position. I don't think you just slap it on and it works, cam timing vs piston position needs to be synced right?
RAT FINK
Assuming you're swapping like heads, you shouldn't have to do anything special. Turn the engine so the #1 cylinder is at TDC (check the crank pulley timing mark to make sure you're not 180* out) while you have the head off, then when you put everything back together line up the cam sprocket with the mark on the timing cover and you should be pretty much spot on. It's pretty simple on the 2.3L, I did lots of timing belt changes which boil down to the same thing.
As far as mechanical fitment, you can put any head from 76? All the way to the 98-01 2.5 head on any block. The intakes, fuel injection, and ignitions are all that changed, you can use any stock 2.3 exhaust manifold on any head too, except for the egr forts on some of the mid year motors, which I plug.
I have never bought a new head bolt. Not one. I've only broken two of them, and its because on my racecar we torque them to 110ftlbs not the speced 90.
RAT FINK
Yeah, there were no torque to yield bolts on any older engines.
Was that on your circle track motors? I've always torqued the 2.3L head to 85# (80-90 is specified range). OEM felpro gaskets. Have I been lucky thus far, or am I missing something???
They are not torque to yield bolts, they are safe to reuse.
Torque to yield or not, i would never reuse factory head bolts. Some of us have had no issue doing so, but even if John Force himself or even Ford told me it was ok, i would still replace them with new ones. Engine fasteners (anything holding the engine itself together...or suspension related), replace them. Smaller stuff like accessory bolts or putting an interior back together etc., reuse.
RAT FINK
So would you replace the bolts holding the main caps on too? It's not like a bolt is ruined after one use unless it's specifically made that way.
I would not give a second thought to reusing head bolts. The only problem with head bolts is that you often get an inaccurate torque reading as compared to studs since you're turning the entire bolt and friction messes with your torque readings.
Fb93, you obviously have never priced bolts for a 2.3... The head bolts are expensive, and I've never seen a set of main bolts (I know they probably sell them). These motors were designed for German military vehicles in the 60's. They are extremely overbuilt, and the stock block and head with all factory components except the pistons and rod bolts will handle 400-450 hp.
1 - 15 of 15 Posts
