Starting to install the Comp Cams Stage II thumpers tonight, just wondering what directions everyone has used when doing them yourself. I'm just using the hot rod cam install procedure is that correct? I'm also installing the lockouts and found the write up for this also. Also is there any break in time after they are installed before you start rippin on it. May take to drag strip this weekend if it all works out.
