I am going to be installing my 78mm BBK combo today in a few hours! Bought it off the forums for 165 shipped...SO CLEAN! Wish me luck...I am not to most hands on dude. ha
Use a good screwdriver with acr and youll be fine.The Throttle Position Sensor (TPS) will need to be transferred to the new throttle body, the screws holding the TPS to the throttle body are attached with a lock-tite type adhesive and the only way to get them off will be with an impact driver. The other options are to buy a new TPS or to grind the head off of the screws to free the TPS, I just opted to buy a new TPS to make the install quicker.
The throttle body comes with the hardware required to install the new throttle position sensor (TPS) so if you couldn’t disconnect the TPS without destroying the screws it isn’t a big deal. After installing the new throttle position sensor I attached the new throttle body to the plenum.
did anyone have a problem with this?!
i did i just bought the new tps can't wait to hear how much you like itThe Throttle Position Sensor (TPS) will need to be transferred to the new throttle body, the screws holding the TPS to the throttle body are attached with a lock-tite type adhesive and the only way to get them off will be with an impact driver. The other options are to buy a new TPS or to grind the head off of the screws to free the TPS, I just opted to buy a new TPS to make the install quicker.
done! BUT now I have a sticky gas pedal. I called my local shop and said bbk has some problems with that so I am bringin it there tuesday afternoon. I am done with it lol U can def. hear it though!
