Did this on my 02 Mustang and it worked perfectly the first time.
Step 1: Turn ignition switch to ON. All the way forward without cranking the engine.
Step 2: Wait until the seatbelt alarm to go off and stop. About 1-2 min.
-- Steps 3-5 must be completed within 60 seconds or the process with have to be repeated.
Step 3: Buckle then unbuckle the safety belt three times, ending with the belt unbuckled.
Step 4: Turn the headlights on then off.
Step 5: Buckle then unbuckle the belt three times ending with the belt unbuckled.
--After step 5 the safety light will be turned on for about three seconds then go off.
Step 6: Within seven seconds of the safety belt light going off buckle then unbuckle the belt again.
--That should disable the safety alarm if it is currently activated or vice versa. You will see the seat belt light blink a few times to confirm it has been done successfully.
Good Luck. I did it on my first try.
