1 - 11 of 11 Posts
I found a ported and polished lower intake manifold for 200 bucks is that a good price?
forget it.
Windstar swap FTW!
you only use the upper windstar intake for the swap, not the lower windstar intake.
the 01 and up windstar intake requires the use of both the upper and lower. And the 01 up style is better. But $200 is pretty good for ported and polished lower
Nobody uses the 01, everybody uses 96-98.
you sure that works... upper and lower windstar intakes will fit on from the 2001 model windstar? christorres = smart on this topic (as well as pretty much all others), wait for him to leave input on that one
MM's Resident Ricer
they will you just have to use the lower as well
99-01 windstar upper AND lower intakes will work on our 99-04 split port cars
for the 96-98 upper intake from the windstar will work on the 99-04 as well WITH OUT needing the lower.
for the windstar 99-01 you will need the lower intake to fit on our cars
ok well i have a 98 and am going to make it an autocross car so what should i do forget it or take it
1 - 11 of 11 Posts
