1 - 9 of 9 Posts
ANYONE HEAR TRIED THE INTAKE RUNNER SHORTNING TRICK .I SEEN A POST ON SVT PERFORMANCE ABOUT IT JUST WONDERING IF IT WORKS GOOD?
WOT Junkie
I'm with this guy^^^^. Uhhhh, what? Link?
Poo tee weet?
Intake runner shortening is a a good mod to speed up that low rpm airspeed for better low end torque. You gotta buy Crisco though not that generic walmart brand stuff, really lube up that intake.
Might look into presure wave tuning for intake manifold design. I've got a spreadsheet that I set up to determine the dimensions for my intakes but it calls for Engine specifications like Advertised Cam Duration, Desired Tuned RPM, Intake Valve Diameter, etc... But there is plenty of info to help determine what a ball park length for the runners would be if you really look into it.
Basically if you do it, you will lose power below 6K RPM and gain above it. So, unless you are geared around 4.30 or higher and like spinning the piss out of your motor, it's best to leave the stocker alone.
1 - 9 of 9 Posts
