1 - 11 of 11 Posts
I noticed today that my interior lighhts wouldnt turn off. I opened and closed both doors, made sure the switch was off and still they stayed on. I went to Ford and they said it was probably a sticky door switch and to spray WD-40 in the door latches. So i pulled the fuse for now but i notice the car still "dings" when i open doors. Therefore te door switches are fine. What else would keep the lights on??
Just pull the damn lights out bro. who cares. my main light pulled that **** on me, and i pulled it right out. I do have both lights on the side though. You really dont need that many lights in there any way do ya? lol
Ok stupid question, but did you make sure the lights turned off when you turned the key forward? Interior light does stay on for a bit after you open the doors.
yea and if you hear a strange noise from the motor like a ticking or tapping just crank up the music so it goes away .
I_eat_rice
make sure the headlight knob is NOT turned all the way .
or it might have something to do with the dimmer relay .
happened to me once..i just turned the ignition to the on position and then back off and it never happened again
I_eat_rice
or it might have something to do with the dimmer relay .[/qu
Absolutely!!lol Besides your saving weight......:D
hey man i had the same problem with mine. It would not go off and i would get out and shut the doors over and over, i finally opened the trunk and shut it and it went off, i didnt know why it cured it but just letting you know my experience.
what if u cant find ur rubbers in the consol and ur in a hurry?? then i bet u'd wished u had lights
try turning the headlight switch to the right maybe...just a idea id say you have done that already tho
1 - 11 of 11 Posts
