1 - 9 of 9 Posts
Alright I'm ready to get down into the nitty gritty of my build and have got just about everything planned and sorted out but I got one more loose end to tie up. I'm doin a 425 inch Windsor (.60 over with a 4.100 inch stroke) and I plan on turnin quite a bit of rpm with it I'm goin forged everything in the bottom end but should I do a scat crank that's externally balanced with cleveland mains or an eagle crank that's internally balanced but uses standard windsor mains, although I think I can go with cleveland mains with it as well but I need to check with eagle on that. So which would be better for a higher rpm setup?
if you do internal balancing would you need to run 0oz flywheel and balancer?
1 - 9 of 9 Posts
