1 - 6 of 6 Posts
7.5L/460 "SUPER COBRA JET" - 550HP FORD RACING PERFORMANCE CRATE M-6007-F460FT [75612209289] $6,600.00
Click to enlarge
Tell a Friend M-6007-F460FT Front Sump T-pan
460 cubic inch
550 HP at 6250 RPM and
545 ft./lbs. of torque at 4800 RPM. (with headers and 850 cfm carburetor not included)
10.5:1 compression ratio (nominal)
Forged steel connecting rods, M-6200-A75
Hydraulic flat tappet camshaft, M-6250-C460
High-performance T-sump oil pan
Front sump fits most passenger cars that came equipped with front sump pan
Rear sump fits most Fox body cars
MSD billet distributor
High-flow aluminum water pump, M-8501-C460
Ford Racing "Super Cobra Jet" aluminum heads, M-6049-SCJ with Ford Racing valve train
Ford Racing “Victor” single plane intake manifold M-9424-G429
460 2-bolt main short block M-6009-E460, oil and water pumps, oil pan, flywheel, and harmonic balancer
A serious high-performance engine
Depending on your application, a different timing cover, water pump, performance oil pan and pickup may be required. See installation notes
just dosent sound right..what do yall think?
well first off you can build that much power easy without being a big block
i kinda like the idea of a big block fox tho....and i got a whole lotta room for when this becomes a full race car....
Click to enlarge
460 cubic inch
Its a TURD!!!!
not to bad but 6600 could go far with a windsor 4 bolt block and a good set of heads.....maybe yates nascar heads? you can find them at nascar auctions and on ebay for reasonable prices for one of the bets ( if not the best) sbf heads out
1 - 6 of 6 Posts
