1 - 17 of 17 Posts
I have a 5speed 96 gt with cold air, underdrive pullies, nos fuel pump, 373 gears, and full exhaust and the thing is slow! it has about 120k on it. I want it faster but i am not confident enough to do a PI head swap, i know i could do the intake and maybe cams. Is the intake actually worth it? i've heard it adds about 15hp but i want to hear from you guys what your experiences have been with PI intake swaps.
i heard the full PI swap has gains of 50 to 60 hp with heads and intake
ive been thinking about doing this, maybe ill do the intake and either search for a set of heads or go with good ported heads. I heard the full swap makes more power than an actual pi motor cause of raised compression
I would say that the full swap makes about 40-50 untuned and can make 60 with a tune. Just by going from what I've seen. I never put mine on a dyno. Tuned it myself
What is included in just the intake swap?
i have an 02 pi motor in my 96. is the lower end of a pi motor better then the stock 96
if so what would be the difference? i know everyone gets the intake and heads but what about the rest of it ?
Its the same bottom end.
The 96-98 have flat pistons and more volume in the head while the 99-04 have dish pistons and less combustion chamber space in the head.
There both weak as **** though
Rollin' 18/ pushin' 2
:no The 96-98 have a 12cc dish and the 99-04 have a 17cc dish.
i did the pi intake swap an i noticed i differents in the upper rpm range
It's like baby steps. We have similar set ups and I installed a PI intake first, the change was nice. Then 3 months later I installed PI cams, also a nice change. But again you will want more (well I do). So now I am shopping for PI heads and maybe a slightly better than pair of cams. But part of my reasoning is I think my valve seals are leaking a little now (puff of smoke out of the tails periodically).
Changing cams (and I removed the front cover) take a little bit of know how. I feel like another day (working) by myself and I could have gotten the heads as well.
Good luck with it.
Discussion Starter #16
i'm gonna go for it, i've read a bit about the swap and i'm pretty sure i can tackle it in about a day. I found a complete 99 intake and throttle body/plenum for $100. if i grab it should i use the 99 tb or stick with by 96 tb?
you could use either throttle body
1 - 17 of 17 Posts
