Hey all. About 2 months ago my mechanic installed a new clutch. He also added some kit that makes the clutch a lot lighter so it takes way less pressure to push the pedal. All seemed well. It's the first time I've had the clutch replaced. Within days the car started making a squeeking noise that was obviously in sync with the spinning of the clutch. When I put even the slightest bit of pressure on the clutch the sound goes away. Fast forward 2 months. It's still doing the same thing. I bring the car into my mechanic and after checking it out they tell me that the clutch bearing is bad but luckily it is covered under warranty parts and labor. I'm thinking "great." Then they call me back a little later and tell me that after getting in there they can tell the reason the clutch bearing went bad is because of a bad clutch cable and that if I don't replace the clutch cable for 300 dollars parts and labor that the bearing is going to do the same thing. Are they taking me for a ride and just trying to get some money out of me rather than doing it for free or is this a legitimate reason why the clutch bearing would be going? Also is $300 a fair price to have that replaced? Thanks in advance for any help.
