1 - 20 of 28 Posts
1 bar = 14.5037738 psi
so that has a range of -15.94 to 44.96 psi
vacuum is usually measured is in/Hg, which would make your range:
-32.46 in/Hg to 44.96 psi (what a typical mechanical gauge reads around)
I wasn't certain which one I had ordered.. cause it's on the way here.. but after looking at my receipt online I did order the one dcook_14 posted the link too
I just went outside to see.. the boost gauge i have now is one with a needle.. and at idle the vaccum is around 14.. So im assuming this gauge should work fine
I mean the car is cold.. i dont know if that has anything to do with it.. but it was in the 14-15 range at idle.
Yeah that's low, it should be around 20. Unless for some reason your elevation messes with your vacuum readings...
my vacuum reads -15 at idle, -20 if there is any load in low rpms. do you have cams?
US Air Force (retired)
It will read less vacuum when you have cams. My is 18-19 in.hg. at idle. When I'm let off the throttle from WOT it goes to 20.
Discussion Starter · #11 ·
no my car doesn't have cams..
Does your current gauge stick? Mine does. It sometime reads 16 in.hg at idle. When I tap the gauge it drops down to 18-19.
Discussion Starter · #13 ·
I dont know i will have to check.. Does the digital one i have the link posted to look like it would work?? I got it in the mail today. even if the vacuum wont read low enuff does that realy matter? as long as it reads some and will read all of the actual boost
The advertisement says it effectively measures within that specific range. The way its worded I don't think running more vacuum will damage the gauge. It certainly will not hurt your car. Most cars do not have vacuum gauges.
Discussion Starter · #15 ·
yea I already have an autometer gauge with the needle.. im not gonna full uninstall that one. Im gonna just hook this new gauge up under the hood and test it real quick to see if it seems work properly. before i start taking the old guage aloose.. I just was tryin to go digital on all my gauges
Discussion Starter · #16 ·
i just finished hooking up a digital Tach gauge with shift light.. Im really happy with that, over top of the 5" needle tach that I had..
Discussion Starter · #17 ·
Talked to tech support they said the gauge will work fine past -14.5 vacuum. that the ditials just dont read lower but it will post ur vacuum number x 2 when it's over 14.5
I was at -14 for a while but finally figured out why, the clear vacuum line going into my rubber vacuum line wasn't a solid connection. So I'm back at -21 in hg at idle.
Where do you guys t off for the gauge? I use the hose coming off te back of the plenum sense that's manifold pressure.
I like the idea of a digital gauge too. I was thinking of getting an AEM Digital boost/vacuum gauge. I think it looks badass. Plus itd be easier to see the boost Im making.
Discussion Starter · #20 ·
yup it does look bad ass.. I got 3 new gauges to go in my car.. all digital... a fuel pressure, wideband air/fuel, and boost... I ordered all mine from GlowShift Performance Gauges & Pods ? Automotive Boost Gauges, Pyrometer I also got their digital tach gauge. Im installing all of them this weekend. once im finished I will post a pic in here so u can see how it looks
1 - 20 of 28 Posts
