Well i bout some GT40P Heads With Lunati Valve Springs Good For .600 Lift.....bought them like that and they are only 8k miles since the springs and new seals and stuff....i may have them milled .030
gonna run stock cam and hopefully be able to buy 1.7 RRs by the time i do this build....this summer..
trickflow street heat intake thats on the car now
im gonna buy injectors because mine are crap....would 24s be good for this setup on a 306....I plan on doin a 150 wet plate kit down the road
should i go 65 or 70 mm throttle body
and i know this has been said a lot but the stock hears will work with the p's for now right
Whats a good rebuild kit....i guess ill have to wait to buy it tho because im not sure if ill have to get the cranked turned or not so i dont know what bearings to get....lost oil pressure and found bearings in the oil so ill probly have to get it turned right?
also plan on rebuilding the t5 while its out so whats a good rebuild kit for it?
