Yea thats what I thought just wanted to check. Thanks for the response.If they don't have grease fittings, don't go adding any! There should have been some red synthetic grease that came along in a little tub or tube, apply that liberally to the outer surfaces of the poly bushings (unless they're not poly bushings :dunno )and you sir, are all set. Have fun!
Will do. Thanks.The bushing design completely seals the grease in. The inner spherical bushing does the actual work. The 2 outer bushings are there to dampen any NVH and the real nice side effect is the fact that they seal the grease in. Just make sure to pack the grease in there real well.
You're welcome.Yea thats what I thought just wanted to check. Thanks for the response.![]()
