ok should i get a JLT or C&L cold air intake for my 04 mach 1
Its not really a fitment issue other than the ram air tube not wanting to stay in the heat shield. The heat shield is a plastic POS that looks like they cut the hole in it with a steak knife. The quality of the heat shield isnt even respectable.Why do most of you complain about the fitting? The heat shield happens to fit perfectly fine! And the numbers and gains are respectable. If you ask me, it seems like some of you may have been either impatient or unwilling to make it fit. My RAi doesn't rub nor have i had a "fitment issue". Its up to you.:yes
