1 - 12 of 12 Posts
Stock studs work great. I wouldn't use anything except the stock Ford gaskets.
Easy as that :)
Another + on the stock gaskets.
Stock studs work fine but I have done a couple LT's with the Stage 8 locking bolts and REALLY like them. Need to keep in mind the stage 8's are MUCH easier to use with an engine on a stand instead of in the car.
In the car they may be more of a PIA unless you have the k-memeber dropped.
Copper gaskets are good, I used the percy aluminum and love them. They are reusable as well. As for bolts arp locking or if your on a budget the Medelin bolts (or somthing like that are pretty cheap and a little better than factory.
You can also get a variety of fasteners from Pro Weld Performance Parts. I am using stainless studs from them on my new engine (along with a bunch of their others fasteners).
Discussion Starter #9
i plan on dropping the k to do the install
1 - 12 of 12 Posts
