I cannot deside between these two chargers. One thing that i dont like about keene bell is the bost a pump, i dont know much about it but i know the whipple comes with the gt500 pump. here is what the kits come with please tell me what you think is better for a dialy driver, and witch one would be easyer to install?
MAJOR KENNE BELL KIT COMPONENTS
Billet Twin Screw 2.6L BIG BORE Supercharger
Hi-Flo Aluminum Inlet Manifolds
Billet Bypass Valve Assembly with Valet Mode
Bar and Plate Intercooler (”Intercooled” kit only)
Intercooler Pump (”Intercooled” kit only)
Water Fill Reservoir (”Intercooled” kit only)
93mm Cool Air Kit
90mm Lightning Mass Air Meter
Kenne Belll Calibration (Optional Dual Calibration ”Power” & “Shoot Out”)
39lb Injectors
BOOST-A-PUMP™
160° Calibrated Thermostat
whipple
93mm Cool Air Kit
39lb Injectors
BOOST-A-PUMP™
whipple
- Instant boost, zero lag time for incredible throttle response
- Revolutionary W140ax Whipple twin-screw supercharger
- Massive 5” thick aluminum intercooler for superior cooling
- Oversized Fluidyne heat exchanger for increased cooling capacity
- Ford GT 38lb/hr fuel injectors
- 0 degree Ford Racing spark plugs
- Twin screw supercharger is the most efficient SC on the market
- Exclusive TRUE cold air intake system with 9” S&B “True-flow” filter
- Self contained oil system, no tapping oil pan
- Industry leading 95mm mass air flow meter
- Exclusive cold air intake system with 9” S&B “True Flow” filter
- Ford Racing flash programmer for industry leading power, reliability and durability
- Zero tuning required, all pre-set
- Available non-intercooled and intercooled
