1 - 15 of 15 Posts
Anandavenkatakrishnan
You can put any center cap on. Just go on AM.
a.k.a. Racecougar
...What did you just ask?
Am has center caps. 6.99 -6%
The OP is referring to the knock-off or spinner style centercaps.
OP, I'm sure someone sells them, but I haven't researched it. A quick Google search for "mustang tri-bar centercaps" turned up a lot of hits.
I smell like beef
I got mines from AM when it was still mustangtuning.com. This was like 2005, and they were over $200 then. I haven't seen any for sale lately. Back when AM (MT) had its own forum, I was one of the only ones that had these. I'll sell you them for 1000 dollhairs.
BAM!
I smell like beef
* did some research, they were made by a company called BRS. They appear to be out of business.
BAM!
I am not wild about fake stuff (ever since that girl in the 7th grade), however they look good--much better than I had thought...
I smell like beef
I personally like the the spinners. They give a pretty common wheel a little bit of character. I'd call AM and see if any spinners are compatible with your wheels. Some of them look like they are just press in. I know the ones I have have a bar and bolt thru the center behind the pony cap. The actual spinner part then screws on and is held with a hidden set screw. They are impossible to remove without removing the wheels.
Discussion Starter #15
Yes...
Those are the ones I'd like.
Thanks for the help. If you stumble across any let me know. I've been doing a BRS search for a while but it appears the last time anyone spoke of these was in '09.
1 - 15 of 15 Posts
