1 - 15 of 15 Posts
Token asian guy
I have 20x9 in front and 20x11 in the back. So you can definitely do it. :p
Yes, I am your Daddy
i heard that if you put 20's on the front, you need to get that roush kit that stops your steering.
what size tire are you running swerv?
Swervo, that's awesome to hear.
While I might not have Forgestar's in my sights, I have long been considering 20's and that is rather assuring information.
Well, you want to run any larger than a 295 (I am running a 315 NT05R) you WILL NEED an adjustable panhard bar to keep from rubbing on one side. Our cars are not centered from the factory and typically sit a little off center to the driverside.
Discussion Starter · #13 ·
That's the car I just bought Grabber Blue CS - now did you have to mod anything in the rear with the 315's ?
Token asian guy
Nope. Just stuck the wheel on and it fit perfectly. Just make sure the wheel you have has the correct offset.
Just had 20'' Steeda Spyders with Nitto NT-05 275/40 in front and 315/35 in rear..didnt lower it and didnt install the panhard.. and i have no Rubbin issues or whatsoever.. though the panhard is must if u wanna lower the car to keep from rubbing on one side..
1 - 15 of 15 Posts
