Thats the point of the 2 step, you dont just hold it down till it kicks in and set there. You hold it to the floor. Now im not saying I sit like that for a long time. I only put it down when the tree is on the second yellow. And I have slicks and suspenion so that im not worried about. Thought about somehow hooking it up into my linelock swich so that it would somehow interupt the nitrous until I let go.Use a push button activator. Launching on the juice will probably require slicks and a good suspension. The WOT switch will also work, because i hope you are not holding the gas at WOT while on the 2 step!![]()
:yesHe's got a built rear.
You can generate SERIOUS amounts of heat while on the 2 step. The rev limiter pulls fuel to control the rpms. You should use just enough gas to hear it bounce off the limiter, then floor it when you launch.Thats the point of the 2 step, you dont just hold it down till it kicks in and set there. You hold it to the floor. Now im not saying I sit like that for a long time. I only put it down when the tree is on the second yellow. And I have slicks and suspenion so that im not worried about. Thought about somehow hooking it up into my linelock swich so that it would somehow interupt the nitrous until I let go.
